PR is creating multiple PO
  • 1.  PR is creating multiple PO
    Posted Jan 30, 2019 02:35 PM
    HI All
    Please advise why a single PR with one line creating multiple Purchase order and would what be the fix to avoid this in future
    Thanks and best regards
    Nazim Lalji
    Dynamics AX Analyst
  • 2.  RE: PR is creating multiple PO
    Posted Feb 05, 2019 12:50 PM
    Hi Nazim,
    Do you have any Procurement policies created? For purchase requisitions, it's possible to create a Procurement policy with a rule against it that automatically splits orders if lines have different requesters, line types, or procurement categories.
    For example, after I create a rule, I can assign a policy rule type to apply to it:
    once the policy rule type is added, it can be configured for order splitting:
    These can be setup in Procurement and Sourcing > Setup > Policies > Purchasing policies (may still be called Procurement policies in AX2012, I'd have to check).
    Drew
    eBECS Limited
    Atlanta GA
  • 3.  RE: PR is creating multiple PO
    Posted 18 days ago
    I'm facing the same issue. I have checked and confirmed that there are no split rules set up. The PR in question is from the same requestor and procurement catgeory - 8 lines on the PR has created 3 separate PO's.
    Is there anything else I should be checking?
    Rhiannon Gibson
