Reports Using Derived Financial Hierarchies
  • 1.  Reports Using Derived Financial Hierarchies
    Posted 25 days ago
    I have seen many posts as to how to create a Derived Financial Hierarchies, I have yet to come across one as to how to report using these.
    Can anyone point me to how I can report on these?
    Thanks!
    Jonathan Struble
    Campus Management
    Bel Air MD
  • 2.  RE: Reports Using Derived Financial Hierarchies
    Posted 24 days ago
    Jonathan,
    I am not sure what you are looking for report wise.
    You can see these in the Trial Balance, Voucher transactions or the dimension statement report.
    The derived dimensions just default on objects (default dimensions) on things like Item, Project, Vendor, Customer or Fixed Asset. This is so you could enter in BU and then everything just populates.
    Additionally, the other big reason I set this up is for AP invoice processors. if they have 3 dimensions to populate and it is turned on then they could populate the BU and all the rest might populate. This is where the defaults and updates happen on "Ledger Dimension" in the journal itself.
    There is no specific report for that all these dimensions just pass through to the Ledger Transactions and you can see them there.
    Hope this helps???
    Chad
    Chad Carnes
    Director of Consulting and Solutions
    EmpowerAX
    McKinney TX
  • 3.  RE: Reports Using Derived Financial Hierarchies
    Posted 24 days ago
    Thanks Chad,
    I guess what I am not understanding is how they appear in the Trial balance for example.  Can you supply a screen shot or description as to how/where I would see reporting by these?
    Thanks again !
    Jonathan Struble
    Supervisor
    RSM
    Bel Air MD
