Mass changing item cost in D365 F&O
  • 1.  Mass changing item cost in D365 F&O
    Posted 18 days ago
    Hello, Is there a way to mass update item cost We have situation were the cost was incorrect when we migrated from AX to D365. I've tried the inventory closing>adjustment but it looks like it only allows one at a time.
    Anilda
    Anilda Pena
    Sr. IT Business Analyst
    Omniparts Automotive
    Franklin TN
  • 2.  RE: Mass changing item cost in D365 F&O
    Posted 17 days ago
    Which costing method are you on  Standard, FIFO, etc.?
    Michael Mills
    Blue Horseshoe Solutions
    Carmel, IN
  • 3.  RE: Mass changing item cost in D365 F&O
    Posted 17 days ago
    We use Weighted avg.
    Anilda Pena
    Franklin TN
  • 4.  RE: Mass changing item cost in D365 F&O
    Hi Anilda,
    I am by no means an expert on the inventory module, however we had a short-lived business line that required us to make modest use of the inventory modules and had this same issue when it came time to writedown the inventory.  We had some success with the attached spreadsheet which can be imported into D365 using Data Management.  It creates an inventory movement journal.  Note that each item number removes inventory from a site/warehouse at its current value and then move it back into the same site/warehouse at the new value.  The offset account takes the net amount as the write-off expense.
    Mark Schurmann
    Accounting Systems Manager
    Automobile Protection Corp
    Norcross GA
    Attachment(s)
  • 5.  RE: Mass changing item cost in D365 F&O
    Hello Anilda,
    Firstly, do you have physical inventory with the wrong cost? If yes, you should download all inventory on-hand and then make an issue of it by using a inventory movement journal. You can type the lines in mass by using the Add-In tool in Microsoft Excel.
    I recommend that you save this file or print the journal for future references.
    Once you have done that, you have to do another movement journal for the entries with the right cost of all your inventory. This will correct the cost of the products as they now are entering with the right cost. In our experience, the "Latest cost price checkbox" in the released product details must be active in the item, so this be the price that will be reported. You can read more about the weighted average in this document: https://docs.microsoft.com/en-us/dynamics365/supply-chain/cost-management/running-average-cost-price
    If the product does not have existence, there's a way to change the cost price of the items in mass by using the "Pending and active item prices" entity in the Data Management Workspace. However, to do this you must have an active cost version (it may be a planned cost version or an standard version).
    Hope this has been useful.
    Best regards!
    Lizzeth Arredondo
    Col. Polanco Chapultepec
