  • 1.  Quality setup and functionality
    Posted Apr 05, 2016 08:45 AM
    I'm new to the Quality portion of AX, however, our quality dept does use it on a limited basis.  I've been tasked with finding out the following information.
    I'm assuming the questions below are all base functionality.  Where would be a good place to start learning about this?  Any information would be appreciated.  Thanks, Sam
    1.  Quality
      1. Review base quality module functionality
        1. How do we collect and retain data?
        2. How do we use quality with production?
        3. How can the system queue us on next steps when the part has a quality requirement
    Sam Clark
    Business Systems Analyst
    Team Technologies
    Morristown TN
  • 2.  RE: Quality setup and functionality
    Posted Apr 05, 2016 11:17 AM
    Edited by Evan Pavan Apr 05, 2016 11:17 AM
    Technet is usually a good place to start to get an overview of the 2 main pieces; quality orders and quality associations. And also figure out the forms:
    About tests and quality orders [AX 2012]
    Microsoft remove preview
    Additional steps include the definition of sampling plans and the assignment of tests to a test group, together with the quality specifications, AQL, test sequence, and validity dates for each test in the test group. The automatic generation of quality orders requires an additional step to define the quality associations about the events and conditions in each business process that will trigger a quality order.
    View this on Microsoft >
    About system-generated quality orders [AX 2012]
    Updated: January 26, 2012 Applies To: Microsoft Dynamics AX 2012 R3, Microsoft Dynamics AX 2012 R2, Microsoft Dynamics AX 2012 Feature Pack, Microsoft Dynamics AX 2012 When you set up a quality association, the system can generate quality orders for various business processes, events, and conditions.
    In terms of your questions
    Quality orders will be referenced to the order where it generated from IE. PRODO1234.
    Quality orders can be queried from the original order from the action tab (prod order pane, purchase order pane) or from the inventory inquiries.
    All testing data is stored on within the quality order.
    2.How do we use quality with production?
    Quality associations can be set up with production route operations, or at report as finished to trigger quality orders.
    Quality associations can be set before or after defined events (before or after receipt), and can also be set to prevent events (prevent production END, or invoice)
    Evan Pavan
    Solution Consultant
    AXSource Global
    Toronto
  • 3.  RE: Quality setup and functionality
    Posted Apr 05, 2016 04:29 PM
    Thanks Evan!  I appreciate the information.
    Sam
    Sam Clark
    Team Technologies
    Morristown TN
